Originally Posted By: rcooke This post was automatically imported from our archived forum.
aobrien wrote:
Does anyone know what procedures to take in order to close a hottub for the winter months in Canada. Electric bills are too high.
Thanks
I would drain it and then make sure I put some 40 degree wind shield fluid through the pump so it does not split when the weather turns colder.
Not a lover of plumbing anti freeze as it kills the grass. The best idea is to pay an expert to do it for you and stay and see what he does.
Originally Posted By: lkage This post was automatically imported from our archived forum.
rcooke wrote:
The best idea is to pay an expert to do it for you and stay and see what he does.[/quote]
I use this method when I don't know. If it's complicated, I take notes. Usually ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif) I can then do it myself.
Originally Posted By: mlong This post was automatically imported from our archived forum.
rcooke wrote:
Thanks
Just draining it won't quite do it. There are often loops in the plumbing of a spa that prevent it from completely draining with gravity, or even with a pump. After draining it as much as possible, use a wet vac to suck out the water at the jets, drains, etc. If possible, disconnect the union at the pump(s) and do the same. Then I would inject RV antifeeze into the pump with something like a turkey baseter (not sure I'm spelling that right) (big hypodermic needle). Oh yea, then pray to the weather gods.
You may also want to hire an expert to do it.
My best recommendation, however, is not to drain it. The bitter cold can be hard on your pump seals (unless you have your pump filled with antifreeze) and also hard on the seals at your jets, drains, etc. If I were you, I'd turn the temperature down to 40-45 F and keep it running. Of course, if your in an area that may be prone to extended power outages in the winter, you may want to drain it anyway.
Great sites thanks Fred . An added bit of information for all those who go south for the winter .
Dish washers and other things that do not like to go dry as the pump seal likes to be kept wet is to take some vegetable oil
( Corn or and other ) put in a couple of ounces on the top of your antifreeze it helps to stop the liquid
from drying out and helps the seals to stay soft.
This also works for floor and other Drains ect.
