This outlet is non GFI. Home is 1978. My question is this outlet above H2o supply ok? :neutral:
I recommend all outlets around water be gfci protected for enhanced safety. You can too.
I believe the NEC still requires GFCI with in 6’ of water
The question is way too vague for an accurate answer, but there is no longer a 6’ reference in the NEC.
I believe you are correct Jeff.
It is my understanding that all Kitchens and Bathrooms , and garage shall be GFCI protected and the rest of the House is on AFCI’s.
Jeff when did this come about. I found this on the net from 07. thanks
http://ecmweb.com/mag/electric_branch_circuits_part_2/
No. Current standard is ALL recepticles above countertops or on islands.
Pretty much every one except serving the fridge or on the walls (not above countertops).
Hope this helps;
I got to get me the new book, thanks to all
