check out these pics.
house built in early 1960’s
panels in bedroom closet
almost 100% that the small box is acting as the 30 amp overcurrent for the AC.
power supply to it is the double tap on the 50 amp breaker at the top right.
I understand the double tap is wrong.
I also understand that the white “hot” wires in the smaller box should be labeled black.
Single self-tapping machine screw was holding the front cover on.
Am I just looking at an issue of support/protection of the romex hanging outside the panels?
Am I missing anything else?
The reason the wording showed up later was because the clothes caught on fire (not a good thing). If it was unsafe in the 80’s, then it was also unsafe in the 60’s and should be reported as such. Recommend an electrician to evaluate. The buyer then determines what course of action to take.
Double taps @ Main OCPD??
White (neutral) going to breakers
bunched Wires under One screw
Missing fittings (as pointed out already)
OLD cloth wire (scary)
Open OCPD Knock out See first pic with panel cover on…
Main panel bonding…Can’t see it
Red wire going to neutral buss for …???
Sub panel neutral and ground separated…Can’t tell
Service panel legend marked or just hack job markings… See service panel
label…can’t tell if properly marked…
Sloppy wiring job… DIY’er
