This video reviews a lift station inspection at a recreational facility. The property has an overhead sewer configuration. In these systems, wastewater is typically lifted to the building sewer by a sewage ejector pump, which may be installed as a standalone unit or as part of a larger lift station enclosure.
The walkthrough explains that ejector systems can vary widely depending on building size and design. Smaller buildings may rely on compact grinder pumps, while larger commercial properties often use multiple submerged lift stations housed within underground pits or vessels. In this example, several large lift stations are present beneath diamond plate covers.
Refer to the Understanding Sewage or Ejector Pumps at Commercial Buildings article to learn more.
