Originally Posted By: mboyett This post was automatically imported from our archived forum.
bbadger wrote:
It sure looks like it was designed for disabled access.
I know & that crossed my mind so I looked for other ADA compliancy. There were non-compliant door thresholds, no handicapped accessories in the baths, no ramps for wheelchairs, etc, etc. Besides, it was a brand new tract home, mid priced, no special features, Realtor said other homes in the subdivision constructed the same way. Got me
escanlan wrote:
Maybe it was installed by a vertically challenged person with no ladder!
Well, now that you mention it the buyer was a little fellow but not that little !
Originally Posted By: pdacey This post was automatically imported from our archived forum.
Does the feed from the SE panel come from the slab or from above? If from the slab, maybe someone didn’t leave enough slack in the line to have the panel at a normal height.
Originally Posted By: jlybolt This post was automatically imported from our archived forum.
From a safety point of view, I wouldn’t consider getting down on my knees to work on the panel very safe. I think I would at least mention in my report that panels are not usually installed this low.
Maybe I should have put something in the report about it but I didn’t. My client and I did discuss it verbally at least so he knows that it is very low compared to other installations but not necessarily wrong.
Thanks Gerry, I don’t have much need for ADA compliance documents since I don’t do commercial/industrial construction management anymore. You can see from that link the ADA requirements are quite complex.
Be aware this file is 26,000 kb 330 odd pages so it will take a while especially on dial up.
Interestingly, distribution panels a re not covere by these regulations as they are not concidered to be in regular use, while I am thinking about it here is a good image from the regulation.
Originally Posted By: dbowers This post was automatically imported from our archived forum.
Michael -
As you and everyone else realizes - the panel appears to be non-compliant. In short it appears to have been installed wrong. At that point the only question is do you report on it or not. Verbally telling someone without putting it in writing doesn't mean squat if there was ever a dispute that ends up in court. In real estate transactions the laws say - if it isn't in writing, it never happened. Just food for thought.
Dan,
Sorry, I have to disagree. What standard, rule or code do you think it is non-compliant to? I haven’t seen anything definitive that says it is not installed properly.
