jpope
(Jeffrey Pope, CMI)
August 19, 2012, 1:03am
21
While the “extra inch” isn’t much of a big deal, the 10 foot reference was completey inaccurate.
The clearance requirement comes into effect when the drop is *“within ten feet horizontally of the waters edge.” *If the drop is outside of that distance, then normal clearance to ground (10 feet) or driveways (12 feet) are required.
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 1:50am
22
Then you better tell Nick to correct it in the How to Inspect Pools and Spas course.
All it says is 10 feet horizontaly from the pools edge.
jritter
(John Ritter)
August 19, 2012, 2:42am
23
NEC section 680.7 pools hot tubs, spas shall not be placed withih 10 feet ofservice drop or overhead service.
NEC 680.22 Receptables must be at least 10 feet from inside wall of pool and must be GFCI protected.
Some transmission lines require 22.5 feet distance but not electric
motors and switches can be within 5 feet if a wall ,fence or other barrier is present.
hope this helps
ccurrins
(Christopher Currins, CMI)
August 19, 2012, 3:01am
24
jritter:
hope this helps
Are you saying a pool can not be placed under a service drop, regardless of vertical clearance?
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 3:10am
25
Thanks John for comfirming this! 22.6" is recommended as a safer distance from the pool from the service drop or transmission lines in the “How To Inspect Pools and Spas course.”
ccurrins
August 19, 2012, 3:21am
26
John did not confirm anything. Jeff P explained Exactly what the requirements/code are for service drop clearance at pools.
Once again you have no clue.
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 3:47am
29
No if you can’t figure it out I wont go there again!
ccurrins
August 19, 2012, 3:55am
30
Already new that was your answer. Can’t wait for Jeff’s response.
Jim_Port
(Jim Port)
August 19, 2012, 1:57pm
32
Seems to be contradicted by this:
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 2:12pm
33
This is exactly what it says Robert on page 50.
Overhead Conductor Clearance
There should be at least 22 1/2 feet clearance in any direction to the water level , the edge of the water surface and the base of a diving platform.
mlarson
(Michael Larson, WI Lic. # 1672-106)
August 19, 2012, 2:13pm
34
I’ve heard if you read it on the internet it must be true.
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 2:19pm
35
I think where the conflict comes in as to the 22 1/2 verses 22.5
And what is said is the water not the edge of the pool. However as you look at the reference just given it speaks of a diving platform.
There is no mention of a diving platform in the code.
mlarson
August 19, 2012, 2:22pm
36
Are you that math challenged? :roll::roll:
22 1/2 = 22.5 as in 22 ft. 6"
or didn’t you know that 0.5 ft. = 6"
kwood
(KEVIN WOOD, CMI)
August 19, 2012, 2:29pm
37
It depends Michael on if you add “”"""""""" ‘’’’’’’’’’’’’’’’
mlarson
August 19, 2012, 2:30pm
38
No it doesn’t.
You are simply wrong **AGAIN.
22.5" = 22 -1/2"
Jim_Port
(Jim Port)
August 19, 2012, 2:31pm
39
Table 680.8 in the NEC shows clearances from diving boards and observation stands.
kwood
(KEVIN WOOD, CMI)
40
Here is Jeffreys post.
Possibly, but it’s 22.5 (22-1/2) feet OR at least 10 feet away measured horizontally from the waters edge.
