Panel Question
Originally Posted By: wcampbell
http://www.nachi.org/bbsystem/usrimages/more/panel11.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/panel21.jpg ]
This Ole House-Home Inspections
William A. Campbell TREC # 6372
Serving the Texas Coastal Bend
(361) 727-0602 (home)
(361) 727-0055 (office)
(361) 229-4103 (cell)
Originally Posted By: bhendry
Hi William,
If it was my client - I would recommend upgrade of obsolete electrical system throughout.
I would discuss GFCI's, AFCI's, grounding conductors and the dangers associated with the present system.
Regards,
Bill
![](upload://6W2YnX4wTESErcMziSzPMju9jcW.gif)
This whole set up is unsafe and should be evaluated by a licensed electrician.
Mike P.
Thanks guys, That was my answer also.
Originally Posted By: sramos
For the benefit of us non-electricians- what specifically do you call out on these panels to support this claim?
Thanks,
Steve
Steven Ramos
EnviroVue Home Inspection
866-541-2883
Circuits with out grounds, double taps, splices inside of panel to start with.
Originally Posted By: Bob Badger
There is nothing wrong with splices in panels.
Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
Originally Posted By: Blaine Wiley
Bob,
Isn't one way to fix a double tap to splice the wires with a wire nut and run a single wire to the breaker?
I've never written up splices in a panel if properly done.
Originally Posted By: dbozek
I would have to agree that the panel in question here should be upgraded. You could ground and bond the main disconnect and you could add a few bushings, fix the separated conduit at the bottom, slap a few twin breakers in the panel to do away with double taps, make the neutral bus floating, add a egc bus bar and bond it to the panel enclosure, remove the blue tape for that is an indication of a phase C voltage but there is no phase C voltage present, and maybe even give it a fresh paint job…but WHY? icon_lol.gif
You cannot help men permanently by doing for them what they should and could do for themselves. Abraham Lincoln
