Home built in 1974. The main cutoff is 200amps and panel rating indicated 150 amps max. Does this mean that the panels should be replaced with a panel that is rated for 200amps? Also, had aluminum wiring. Any comments would be appreciated.
I would not voice my opinion .
*If it needs changing then let the professional make the decision. *
Why get involved with something that can come back to haunt you .
- What is the condition do you think it needs an upgrade???*
