Hey yall,
I’m wrapping up my licensing process right now and having some paperwork trouble. I just completed my 10 parallel inspections but can’t find the form (or affidavit) mentioned in section C of the link below. https://codes.ohio.gov/ohio-administrative-code/rule-1301:17-1-14
Does anyone have a template or pdf for this form or should I just use multiple copies of page 7 from the state application?
Right but what I’m asking is: does there exist a form or template that is or has been used by inspectors in Ohio for the purpose of applying for a license?
When HI licensing became law, I was grandfathered and wasn’t required to perform parallel inspections, so I couldn’t tell you if there is a template or pdf for the form or not.
You may want to call Mr. Woodruff, he should be able to answer any questions you may have.
Edward Woodruff
Division Counsel
Ohio Department of Commerce
Division of Real Estate & Professional Licensing
77 South High Street, 20th Floor
Columbus, Ohio 43215
Phone: 614-466-5042 edward.woodruff@com.state.oh.us www.com.ohio.gov
