When is a permit required? What types of work are exempted from permits?
A permit is required for new construction, renovations, or demolition. Projects that involves structural or physical changes or construction that affects safety or environmental issues usually require building permits as well as the various code inspections.
Basic construction projects that are aesthetic or cosmetic updates or general maintenance work are usually exempt from a building permit. It’s always best to check with the local permit department.
I agree, there is no one correct answer due to what has been adopted by the jurisdiction. Some places want permits for just about anything, other places no permits required at all.
Most local governments have a web page that will tell you who to contact for permits and inspections and what work requires permits. You need to look it up for your location.
But you can’t even depend on that. On my fixer some years ago, the plumbing inspector said, “It looks like you changed the tub fixture, but I don’t see that on your permit.” I said, “Because your website says that I don’t need a permit to change the tub fixture.” He said, “Yeah, we need to change that. You need a permit for that.”
Well, wouldn’t you know that my plumber had gone on a bender or something and was nowhere to be found. I had to hustle up another plumber (and pay him) to get the additional permit and inspection. What a scam!
Here in NJ we have items that are considered ordinary maintenance and therefore a building permit is not required. Here a permit is not required if you want to put a new roof on your house go north a few miles to New York State and most jurisdictions do require them for a roof. As with any ordinary maintenance item, although a permit is not required, it is still required that the installation be done to code.
