Attached is a photo of the indoor unit for our townhome’s heat pump. Pictured is the housing, and suction line drawing hot, high-pressure R22 freon gas from the outdoor compressor as it leads into the indoor evaporator.
Your a bit confused on a HP the suction line becomes the high pressure gas discharge line from the reversing valve to the indoor coil
