Good selection for this Month.
Please take the time to Vote and Participate. :)
#1
The garage door opener will fit NOW!!!
http://www.nachi.org/forum/attachments/f11/64292d1366308629t-vote-best-defect-picture-april-049.jpg
#2
In a 130 MPH wind zone in Florida.
#3
A well supported street light pole used as a beam…
http://www.nachi.org/forum/attachments/f11/64317d1366336909t-submit-your-best-defect-pictures-may-here-pic-124.jpg http://www.nachi.org/forum/attachments/f11/64318d1366336935t-submit-your-best-defect-pictures-may-here-pic-125.jpg
#4
Original brick column failed, added wooden makeshift log column, log column eaten by WDO, added another wood column, that too eaten by WDO. Then added an unsecured lolly column on a makeshift “footing”. All columns like this.
edit, one photo was not right side up…
http://www.nachi.org/forum/attachments/f11/64333d1366386754t-submit-your-best-defect-pictures-may-here-column2.jpg http://www.nachi.org/forum/attachments/f11/64334d1366386763t-submit-your-best-defect-pictures-may-here-column3.jpg http://www.nachi.org/forum/attachments/f11/64335d1366390753t-submit-your-best-defect-pictures-may-here-column1.jpg
#6
Who needs gusset plates?
http://www.nachi.org/forum/attachments/f11/64350d1366412426t-submit-your-best-defect-pictures-may-here-p4170050.jpg http://www.nachi.org/forum/attachments/f11/64351d1366412472t-submit-your-best-defect-pictures-may-here-p4170051.jpg
#7
This water heater vent pipe had negative slope and was vented into the masonry chimey with a huge hole in the side. There were bedrooms on the other side of the wall… I shut the water heater off immediately!!
Inside chimney
#8
Here is an old brick built tuck-under garage. Note that the floor is created with poured concrete over steel joist. The owner had a wood burning stove below which heated the lower level. All the moisture/condensation from the stove has caused Major Corrosion to the joist, literally eating them away. Would you park your car in this garage?
http://www.nachi.org/forum/attachments/f11/64362d1366462676t-submit-your-best-defect-pictures-may-here-p4180009.jpg http://www.nachi.org/forum/attachments/f11/64363d1366462697t-submit-your-best-defect-pictures-may-here-p4180010.jpg http://www.nachi.org/forum/attachments/f11/64364d1366462708t-submit-your-best-defect-pictures-may-here-p4180011.jpg
#9
Gas boiler and water heater and NO CO2 detectors OH MY!
http://www.nachi.org/forum/attachments/f11/64452d1366678310t-now-accepting-defect-pictures-april-308-highland-ave-clarks-summit-397.jpg
#10
http://www.nachi.org/forum/attachments/f11/64490d1366752612t-submit-your-best-defect-pictures-may-here-abigail-066.jpg
The TPR or TPV seems to be self replicating. Like an amoeba:roll:.
#11
well it is “duct” tape… maybe they should have used register or diffuser tape…
http://www.nachi.org/forum/attachments/f11/64556d1366912479t-submit-your-best-defect-pictures-may-here-ducter.jpg
#12
More deck issues.They sure know how to build them here. NOT!!
http://www.nachi.org/forum/attachments/f11/64575d1366946093t-submit-your-best-defect-pictures-may-here-img_2885.jpg http://www.nachi.org/forum/attachments/f11/64576d1366946105t-submit-your-best-defect-pictures-may-here-img_2887.jpg http://www.nachi.org/forum/attachments/f11/64577d1366946117t-submit-your-best-defect-pictures-may-here-img_2888.jpg
