dnasser
(David Nasser)
August 3, 2009, 5:42am
#1
Rough cut thru upstairs closet exposing guest bathroom
behind the bath tub…
Physical observation revealed no defects…and I ran the water from the tub faucet for over 10 minutes…no signs of leaking present or past.
Anybody have reasons for this condition ?
David
http://i187.photobucket.com/albums/x296/dawlita/Ajit096.jpg
http://i187.photobucket.com/albums/x296/dawlita/Ajit102.jpg
sstanczyk
(Stephen Stanczyk, WA License #221)
August 3, 2009, 5:50am
#2
Working on the overflow. It looks like there was some dripping at the back of the tub. They probably had a bad gasket or the drain control was stuck or corroded. But seeing the PEX, it isn’t that old. Hmmm. What are the wires for?
dvalley
(David Valley, License #566 - CMI)
August 3, 2009, 10:45am
#3
These type of openings are quite typical behind tub walls. If there’s no obvious water damage, it simply needs an accessible cover.
