I had a friend of mine come across a huge leak in their home. They noticed the sprinkler line had no attachment to center of stud the line was pressed up against drywall any screw or any type of wall hanging wall would puncture the sprinkler line. Obviously the home inspector does not have x-ray vision. It should be on the city inspector or plumber?
And the waterline burst by simple movement no penetration hit it, but it leaked all over the home. The line itself was not attached center of the stud bay or no type of protection, covering the line.
I blame the person who missed the stud with the screw that punctured the line.
Seriously though, I’m not sure there is a code for water line distance from the drywall between studs. Maybe there is, I’m not a code expert or plumber, but I’ve never heard of one. If there is a code, than I guess it’s the plumber’s fault.
Edit: I see you added into your original post that the line was not hit by a screw, that it just burst from movement. In that case, I can only assume there was a ton of friction from some unknown cause. More friction than normal.
