Plumbing - Tub Cracking
This is a good one. The tub has multiple cracks that are quite large. The home owner stated to my client they will seal the tub. I flagged it as hazardous as the cracking more than likely will get worse and someone could be cut or foot get stuck if it were to open up more under weight, not to mention there is a high probability of deterioration of the flooring underneath and mold growth. Can i get some opinions how any of you would handle this to help your client?
Report what you observe. Recommend that a qualified professional make any repairs.
Also photos including an overview help with responses.
Don’t go crazy with the speculations. This may be a good time to keep it simple.
Further damage, leaking, or (injury?) may occur if not repaired or replaced. And I agree with David, just state your recommendation that it be evaluated and repaired or replaced by a qualified person. No reason to get into the minutia between the client and the homeowner.
I agree with Dave.
I understand one wanting to be as helpful to our clients as possible, but regardless of what the homeowner says he may fix or do, the inspection is for the day and time of the inspection, and how it gets fixed, if it gets fixed at all, is not anything that should concern us home inspectors.
Thats basically what I reported and stated, however they are looking for some additional help and i sure would like to help them with some solid information.
You did that. Your words in the report matter. Your recommendation is solid. Let it stand.
Recently, a client reached back to me about an EIFS problem. Her realtor recommended that her painter take a look at the cladding. My recommendation was an EIFS cladding expert. It was a short conversation, I stated I stand with my recommendation, and the painter should be fully qualified for EIFS evaluation and repairs, should she choose to stay that course.
You did your job as far as the report goes, but I would have a conversation with both the client and buyer’s realtor as to getting a professional tub repair person to come check it out. The seller’s statement could mean they themselves would do the actual work … then who knows what that would be. or are they paying for a professional to make the repairs??? Words matter!
Thank you, that will help a lot.
