Polybutylene Piping?
Not sure if
this is Polybutylene pipes?
Upper is for sure, can’t tell about the lower picture.
Thank you, that is all the same pipe.
PB2110 is the tell.
Yep.
what David said ….
Just verifying what Jim said!!,
I agree with Tom.
Is that Flowguard Gold on the other side of the Sharkbite? There are problems with it as well.
Hello Jeff. Would you mind sharing your comment that you put into reports about Flowguard Gold? I’m unfamiliar with the context of it.
The link says:
“Investigation Complete
Attorneys working with ClassAction.org have finished their investigation into this matter.”
Ie, nothing happened. No class action lawsuits were filed.
Flowguard Gold is still being sold today: https://www.flowguardgold.com
CPVC can have problems, no doubt, but so can every type of pipe.
It’s the same argument as Stab-Lok.
Except no makes Stab-lok anymore.
And, right or wrong, many insurance companies will not insure homes with a Stab Lok anymore.
Love or hate it, CPVC meets UPC (Uniform Plumbing Code) 604.1.
And in my case, California Plumbing Code Section 604.1
I’m pretty sure it’s ok per the IPC too.
But PEX is pretty much the material of choice by builders now. I don’t see a lot of CPVC except in one neighborhood.
There are a plethora of failed CPVC installations in this area.
Here’s the Inspectapedia deep dive…
But… PEX is the new poly. :wink:
The reason that I knew about the problem with FlowGuard is from when I did insurance inspections. It was on the list of problem materials along with PB-2110 and galvanized. Not all insurance companies around here will insure, or cover damage caused from its failure.
I hardly ever see it around here either. Maybe once out of every 100 homes and it is never a complete system. When traveling for FEMA, I see it all the time.
I used to think that. I’d say “just wait, one day, we’ll hear Pex is bad…”
But it hasn’t happened. It’s now the pipe of choice in new builds around here.
If you build with copper, you have to worry about people stealing it in the middle of the night.
No one wants to steal PEX. :rofl:
I just worry about Rodents chewing on PEX. :mouse:
It’s in the works there suits against every major manufacturer… More are coming.
There has been class action lawsuits for PEX. It was for the brass fittings and not the actual pipe itself.
I’ve seen the engineer analysis of PEX pipes (less than 5 years old) that failed that were in the midst of a lawsuit. The pipes crack from the inside-out, discolored PEX is a warning sign, chlorinated water and excessive heat are suspected causes (chorine in water/hot attics LOL). Unfortunately, many corporations have pivoted to arbitration as the preferred method of settling disputes so the public may never find out about some common problems. PEX is the new poly.
