In Quebec ground pins are positioned up, in Ontario they are positioned down…go figure.
If I notice metal covers with ground pins down, I mention the potential safety issue to clients that a loose metal cover could fall on live prongs if the plug was partially pulled.
I don’t write it up in the inspection report just like I don’t write light switch being down while on. If it was a safety issue then 3 way switch’s would be designed differently in my opinion.
Okay so there was this big big Roman Gallion rowing boat. Its stinking hot the beat of the drum is nauseating hour after hour in the hot sun. Finally there is silence the rowers look up only to hear the drummer say, “men I have some good news for you today, there is going to be a change of underwear!” Shouts of joy errupt, everyone is happy. Then the drummer says, "Frank you change underwear with Harry, Harry you change underwear with Bill…
The way I install a Decora switch is I look at the yoke strap and on one end it says TOP sp, 3way and 4way. I have seen this on toggle switch also in the past (on up). I have seen on outlets and It was ground up.So if not marked I guess it does not matter which way it goes.
Right on! Show me any technical book that shows a single pole switch marked ON and OFF upside down, it is really very simple just tell the buyer that they should be turned around in order to avoid confusion.
I did a home yesterday and all the switches where only 44 inches of the floor.
Normal in my area is 54 inches .
I pointed it out to my client but put nothing in my report.
This is a seniors community and many of us when we get old tend to shrink and stoop.
This to me seemed like a satisfactory solution.
The client agreed.
…Cookie
