He is, he just doesn’t know why… it’s not technically an s-trap, but rather improperly vented p-trap.
Yes that is correct. That P-trap is not being vented at all. I consider this an s trap.
I can go along with that…
I highly recommend CE It’s good for edumication
That’s fine try to get that configuration passed anywhere where s traps are prohibited you’re gonna be fighting an uphill battle. Once the direction of the drain turns down after the p trap you have an s trap. It doesn’t matter if that length of pipe is 1” long of 10’ long. This configuration goes one step further and adds another change of direction until it his a drain we assume is vented.
that is not true…length matters…
Wow! You flippin’ guys are bored…
Go talk to the wife for a while…
That’s what I thought too Jim, but I guess we are being told we are wrong.
What timing for an s-trap post.
This is from today’s inspection
The weir to the plumbing vent was about 3 feet below this trap in the crawlspace.
They still sell S-trap kits at my local HD even though it’s been banned for quite a while in MD. Thank you DIY shows and YouTube!
now that is an s trap…
It’s an attempt at a “Vertical Leg Trap Arm,” which is acceptable in some jurisdictions. It was removed from CA Codes somewhere around 2009.
Thanks, Jeff!
I’m waiting for M Parks to comment before I’m satisfied with a definitive answer.
Chris, leave it to you to stir the pot!
Why when such an excellent job of explaining this has already been done?
I was up in your neck of the woods the last three weeks filling in as plumbing inspector. I do back up for building departments. Electrical, Plumbing and full residential.
Puff Daddy!
