is there anything special i should know
Yes, welcome to the message board, what took you so long.
Did I mention there will be no drywall installed?
Check, plumbing, electrical, backing for cabinets, door stops, tub enclosures, sink base blocking, stair construction, insulation, vapor barriers, framing in general and anything else you stumble upon that is not hidden.
