It’s been some time since doing a pre-pour and am scheduled for one later this week. Are there sources out there to help cover all the bases. I’ve got a pretty good idea of the items to look for but wanted to make sure all my i’s are dotted and t’s are crossed. Thanks for any direction YA’LL!
Richard,
I would inspect it to the code your municipality is currently using.
Not knowing what type of foundation your referencing I cannot help.
If your municipality is using the IRC, (without any local ammendments) post what type of foundation this is.
Slab on grade, footings-stem walls with slab, basement, post tension, etc?
Double post…oops.
Probably 99.99% of SE Texas foundations are slab on grade. How many are PT -vs- rebar I don’t know. Richard…here is a good website for your area that you may already have but, if not, it may give you some pointers. There’s no true checklist at this website though. Try: http://www.houston-slab-foundations.info/
Yes, it was a PT. Thanks for the site. I think I have seen that one a while back. Will save it this time around.
