# Pressure question
**URL:** <https://forum.nachi.org/t/pressure-question/15604>\
**Category:** Plumbing Inspections\
**Created:** [April 21, 2007, 2:01pm UTC](https://forum.nachi.org/t/pressure-question/15604 "2007-04-21T14:01:22Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![mtimpani](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/mtimpani/32/58543_2.png) [@mtimpani](https://forum.nachi.org/u/mtimpani)\
**Post date:** [April 21, 2007, 2:01pm UTC](https://forum.nachi.org/t/pressure-question/15604/1 "2007-04-21T14:01:22Z")
</div>
I had 90psi coming into the house at the main water valve. The bathroom sinks had very low flow and the tub had such low flow that when you tried the shower, water just dribbled out of the shower head. The valves to the sinks were open all the way.
My question is what types of things can I tell my clients when they ask me “what causes this”? (very high pressure- tons of volume - outside, but hardly any water inside)
**Post date:** [April 21, 2007, 2:11pm UTC](https://forum.nachi.org/t/pressure-question/15604/2 "2007-04-21T14:11:22Z")
</div>
Clogged aerators/shower heads?
[http://www.acmehowto.com/howto/homemaintenance/plumbing/faucet/aerator.php](http://www.acmehowto.com/howto/homemaintenance/plumbing/faucet/aerator.php)
**Author:** ![Jason1](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/jason1/32/276_2.png) [@Jason1](https://forum.nachi.org/u/Jason1)\
**Post date:** [April 21, 2007, 3:05pm UTC](https://forum.nachi.org/t/pressure-question/15604/3 "2007-04-21T15:05:19Z")
</div>
> [@mtimpani](#):
What type of supply in the house? Copper, PEX, Galvanized?
**Author:** ![rmccullough](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/rmccullough/32/1667_2.png) [@rmccullough](https://forum.nachi.org/u/rmccullough)\
**Post date:** [April 21, 2007, 3:15pm UTC](https://forum.nachi.org/t/pressure-question/15604/4 "2007-04-21T15:15:47Z")
</div>
> [@lkage](#):
My first place to look also.
But remember PRESSURE does NOT equal FLOW.
**Author:** ![dduffy](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/dduffy/32/554_2.png) [@dduffy](https://forum.nachi.org/u/dduffy)\
**Post date:** [April 21, 2007, 7:18pm UTC](https://forum.nachi.org/t/pressure-question/15604/5 "2007-04-21T19:18:10Z")
</div>
> [@mtimpani](#):
Mark…last week I had the same thing, a plumber installed a pressure reducing valve which did not even look like any I have seen. Outside at hose faucet was 80lbs…In the house was the exact problem, no water.
The house was vacant but the realtor called the owner, he came out and adjusted the valve, all was fine.
![](https://global.discourse-cdn.com/internachi/original/4X/b/f/b/bfbcdfe4b154950d05fa0aaf276e49f0ea8b65dd.jpeg)
**Author:** ![jlybolt](https://avatars.discourse-cdn.com/v4/letter/j/71c47a/32.png) [@jlybolt](https://forum.nachi.org/u/jlybolt)\
**Post date:** [April 22, 2007, 4:19am UTC](https://forum.nachi.org/t/pressure-question/15604/6 "2007-04-22T04:19:05Z")
</div>
Mark what year was the home built. What is the piping material?
To many factors to consider.
**Post date:** [April 22, 2007, 2:02pm UTC](https://forum.nachi.org/t/pressure-question/15604/7 "2007-04-22T14:02:53Z")
</div>
1999 Pex
**Author:** ![homebild](https://avatars.discourse-cdn.com/v4/letter/h/90db22/32.png) [@homebild](https://forum.nachi.org/u/homebild)\
**Post date:** [April 22, 2007, 4:51pm UTC](https://forum.nachi.org/t/pressure-question/15604/8 "2007-04-22T16:51:39Z")
</div>
Check to make sure that the valves at the PEX manifold are fully opened.
