Propane tank age?
i tried to search and am surprised that i came up empty.
what the max age for a residential propane tank? im thinking 15 years, and if its recertified, how may more? cant find anything in NFPA to back it up.
http://www.propane101.com/propanecylinders.htm
same with larger permanently installed tanks filled on site? (im not talkin a BBQ tank)
ASME tank have a nameplate that should have the date of manufacture and be in good condition. No requirement to re certify.
I have some 20 gallon DOT tanks from the 40’s or 50’s, some guy at the propane shop sprayed them with soapy water and punched a new date into them the last time I had them checked.
That works for a lot of things! :margarit:
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
do you mean 20# tanks? BBQ type? if so, im sure this is a no no as tanks have to be equipped with the new overfill valve to be filled.
For being so sure about pressure vessels you ask a lot of questions. :smiley:
Who said anything about valves???
