Caught my son outside chewing on electrical wires, so I had to ground him.
He’s doing better currently and conducting himself properly
there is no compromise when it comes to good parenting…..
I’m not shocked.
That’s a load.
There’ll be resistance and you’ll have to use a switch.
But more power to you as a parent you’ve got to short circuit that behavior.
You probably need to breaker his habit before he hurts himself.
Ohm my God, I bet he was amped.
It sounds like the kid has potential.
He may be equipotential bonded.
Did you have to put him in a 30" x 36" service area until his E=IR?
Are you saying he should be placed in a neutral area until he finds a better outlet for his faults?
I haven’t heard this joke in at least one year.
Shocking.
Ohm my goodness, these are really good puns.
Ampere trying to figure out watt this whole thread is about.
That’s a loaded question. In one line, it’s an outlet for inspectors to have some fun which is a switch from other, more serious topics.
I’m not a parent so I’m Neutral on this situation, though I do hope you and your son Bonded over the experience.
Don’t listen to Larry… using a switch would be Battery.
LOL !!! ![]()
It’s a dimmer thought than most enjoy but relay it to those that will listen.
It hertz to use a switch but consider a smart switch like Farad uses. Or, maybe consider a Low-Voltage or coaxial cable or a pigtail or a splice for goodness sake.
But Kirchhoff’s current law requires something to be added because you are at a junction.
I know, I know, it gives me a terminal block too.
