I’m a new inspector and I’m planning on including radon measurement in my offerings. Has anyone had any issues with theft or damage to the continuous monitors. They’re quite expensive and before I commit to buying one, is the general safety of equipment a non-issue?
Typically (mostly in my experience) yes.
But… You wouldn’t want to set one in a crack house etc. I was always more concerned about the test being tampered with (people opening windows etc to air out the house. There are units which aid in detecting such events. Good luck
I’ve never had an issue, but a little tip… do everything you can to place the monitor prior to the inspection, so that the test is done at the inspection time and you can take the monitor with you.
I’ve had a few I’ve had to retrieve after the inspection, where I knew the deal went south. In those cases, I worried if I would find my equipment laying out in the yard, lol. And I can tell you the sellers are often not happy to see you after a busted deal. Do everything you can to take the monitor with you on the day of the inspection.
Same. Good question by OP and I wondered the exact same thing when we started testing about 10 years ago. In 10 years we’ve done +/- 5,000 tests and never an issue. I actually worry more about a vehicle break-in, although our 1030 Sun Nuclear machines are pretty clunky and I don’t know that a crackhead would be too interested.
Yeah, and it’s sometimes a bit uncomfortable returning to the scene and meeting the sellers after you tore their house to shreds in the report.
Speaking of the machine in the yard, one of my favorites was on a new construction we had a test in. I showed up for the inspection and the entire front door and frame was lying in the yard for whatever reason. Seeing it lying there with the tag saying to leave the door closed was pretty ironic. I guess to be fair, the door was still closed in the frame
Just rent a breeze monitor, they will cover it if anything was to happen.
But to make sure you have enough monitors, you actually need a minimum of 5 units to make it through a work week, just in case you get 2 a day for all 5 days of the week.
You should still budget for a minimum of 3 machines. Remember, you have to send each machine out for calibration annually. That will leave you with only two machines during that time period. That is exactly when you will get multiple requests for radon testing, or get a home that requires two monitors. In my opinion, 3 monitors is the absolute minimum.
I get along with 2 monitors. My radon testing volume and market price point doesn’t justify the expense of three monitors. You need two monitors for multiple foundation types and for duplicates. When I’m down to one monitor, I’ve always been able to schedule multiple foundation types around calibrations. I had a “first of” problem recently; two separate and disconnected crawl space foundations with a basement between them. This is the first time I needed three monitors in 5 plus years of radon testing.
My monitors have a lock that accepts a Kensington type cable lock. I lock my devices to address the tempering component of my Quality Assurance Plan.
If you’re thinking 20 home inspections per year, I don’t think you’ll be able to justify radon testing at this point in your new business. Many home inspections decline radon testing. Last year I did about 30 radon tests. That volume is profitable but is at the low end of being profitable. Licensing, continuing education (including my time $$$), plus calibration costs are significant fixed expenses - about $1200/year.
Hmmm, thanks for the honest reply. I’m in Vermont which, according the the EPA, is a radon prone area and Vermont doesn’t require additional licensing so the expenses would only be recalibration. Maybe I will change up the language on my website from continuous to carbon based canister testing until I get a better understanding of the demand.
Become familiar with and follow these testing standards and institute these Quality Assurance protol for your carbon devices. This is what professional radon testing follows, similar to the SOP for home inspecting. On your web site, you can use “NRSB approved device”, which covers CRM’s and carbon kits.
I have never had a problem, but I do have tool and equipment loos added to my insurance policy. Without looking the price up I believe it runs somewhere between $100.00 and $200.00/year.
Radon testing usually requires at least 48 hours. So, you’ll need to leave the monitor undisturbed for two days (you won’t be able to take it with you at the end of the inspection). Though you may not be able to guarantee its security, you should post a notice (or more than one notice) that radon testing is in progress and not to disturb it.
The device may be sensitive to temperature extremes if left in a vehicle for extended periods. I have done this and had to pay a repair cost.
I have 5 continuous radon monitors and have had occasion to use all of them at the same time. Most of my inspections including radon as and additional service. If I do two inspections including radon on Monday, I need two devices. If I do another on Tuesday, that’s another. If I do some on Wednesday, I’ll likely need another unless I can arrange my schedule to retrieve Monday’s units before placing them on Wednesday.
If you are just getting started, you might consider leasing equipment instead of buying. I know Radalink has leasing, Sun Nuclear, possibly Breeze? There may be others nowadays as I am a bit out of the loop. They will handle calibrations and send you replacements as needed.
As your business grows, your demand increases, and you have some income, then it’s time to look into purchasing your own equipment. If you are testing even somewhat frequently, it will not take long for the monitors to pay for themselves and start making you money.
I started with three monitors 20+ years ago, now have an inventory of eight. Due to multiple foundations and larger homes, there are weeks when I have all eight units deployed.
I had one seller get irate over a deal falling apart and she unplugged my equipment and left it sitting on her front porch. That was the only negative incident I have ever had with my equipment. If you own the equipment, make sure you have insurance coverage.
Ryan how can you take monitor with you after inspection? Have to leave 48 hrs , is there something new that I’m not aware of. We have to be licensed here in California.
I sub all my Radon tests out and have used 8 different Radon Techs through the years to do my Radon tests, I currently use 2 Techs because I cover both the Cincinnati and Dayton markets. The reason I sub them out is because I don’t want to make 2 trips to the property, that and having to be licensed by the state, keeping records of tests performed with the state, buying machines, having to perform semiannual side by side verification testing of the machines and annual calibrations that are required to be performed by a state licensed lab.
In over 23 years in the business, my Radon Techs have never had a machine stolen or damaged.
One thing you might want to consider is, if you’re in a sketchy area, using canisters, if allowed by your state if licensing is required.
