Can anyone tell me what the purpose is of this surge protector located at the exterior of an electrical service panel on a pedestal for a residential dwelling?
It’s connected to a circuit breaker.
What is the device protecting from a surge, specifically?
Does it look like it’s installed before “the main device in the load center?”
To me it appears to be installed on branch circuits.
The NEC is now calling for surge protection on services.
As well as exterior main disconnect.
This^^^^^^
The purpose is to help protect the electrical system from surges. I had an extended conversation with an Eaton engineer regarding a question about a surge protector. He answered my question rather quickly then went on to explain “the more the merrier” that having more surge protection devices provides additional protection. He said he has them at his entrance, on his AC equipment, and other major appliances (fridge, freezer etc). Prompted me to add more to our home.
Ditto.
Gotta remember… as the years go by, we keep adding more and more technology to our homes.
I know damned well I don’t want to replace anything that I could have easily protected.
I’m not that much of a cheapskate!!
A surge suppressor or surge protector performs essentially the same function. To put it in the simplest terms, it clamps the Voltage to protect components from a rapid rise in Voltage. It does that by providing a low resistance current path that shunts the Voltage. In their most basic form, they are selenium rectifiers or metal oxide varistors (MOV). MOVs are usually used in low energy applications such as in residential electrical systems and selenium rectifiers are used in high energy systems.
The suppressors and protectors used in residential applications sometimes employ supplemental circuitry to perform more sophisticated filtering than simply clamping Voltage. For example, they may incorporate inductors to suppress high frequency transients.
We know that Voltage drop in a closed loop is always 100% (Kirchhoff’s Voltage Law). Therefore, introducing a very low resistance will cause close to 100% of the Voltage to drop across the resistance, thus diverting it from the loads that are being protected.
Surge protectors and suppressors are not entirely effective. They merely mitigate the results of Voltage transients. Modern electronics also have circuitry built in that will also help to regulate Voltage, thereby protecting the respective component. While surge protectors and suppressors are not a panacea they offer enough protection to save many sensitive loads from destruction.
Last fall when I was selling my rental property, lightning hit nearby and took out 3 brand new Kichler ceiling fans, the modem, router, irrigation controller and a few other small things.
It had been on my list to add an Eaton Ultra to the panel, but when we decided to sell, I didn’t bother.
It cost almost 2k to replace everything. That home had a Duke Energy type one on the panel. Not sure how much it helped, but I would have to think it did.
I’ve since added a Type 1 to my own house. I’ve had a type 2 Eaton Ultra on the panel for some time now.
It also turns out that if you live near power lines, your risk of a direct strike goes down, but your risk of an induced surge is greater. So if you are within 1000 feet of a 230KV+ tower, it is important to get as much surge as you can handle.
Surge protectors sound useful in theory.
I really have no idea how to determine if they’ve been installed correctly.
They all come with installation instructions.
Or any way to determine if they are functional and/or damaged. Can a surge protector take an unlimited number of surges of any size?
Most have a light that goes off or changes color if it needs replaced. There are many different types, but, No they have limitations.
Does that mean that this thing needs replacing since the light is out?
That’s what it says in three different languages on the device… If it’s installed (correctly).
Ok. That’s kind of a cryptic message on the front without any complete sentences, but now I get it and know a little bit more about what to look for.
Thanks, Dave!
Me too. Good post from you and good info from Dave. Most of my inspections don’t involve a surge protector, so not something I’ve had to do the deep dive on in the past.
Here’s the new comment in my HIP software for defects such as this one:
[[Surge Protector Defect]]The light on the front of the Square D Surgelogic Type Sdsa1175 surge protector on the right side of the electrical service panel was not illuminated at the time of the inspection. When the light is out, the surge protector needs to be replaced, according to a cryptic message on the front of the surge protector. A licensed qualified electrical contractor should evaluate and repair or replace as necessary and according to modern building standards.
The NEC now requires they be installed, so depending on your local code adaptations you may be seeing them more often on newer builds.
