QOD for 04/16/04 (HVAC)
Originally Posted By: gbeaumont
Hi to all,
Here's another HVAC question about hydronic heat (for those in sunnier climes that is heat via hot water running through pipes to radiators ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif) )
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: jpope
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: pdacey
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Originally Posted By: dbush
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: jsavino
Any Repco boiler here on Long Island had to be replaced. The insurance co would not wright the policy. If you come across one, check the rear jacket behind the fire box.Look for metal warping or scorching. That indicates the fire box is burning through. Recommend home owner to call the fuel company to disable the boiler from running. A.S.A.P.
John Savino
HomeWorks Inspection Services, LLC
St. James, NY
631.379.4241
Originally Posted By: Blaine Wiley
We just use solar panels to heat the water for out swimming pools. Boilers, uggghh, I don’t even like the thought of having to use a heating system.
87 degrees and bright sunshine today.
Originally Posted By: psabados
Hey Pat
If you look closely at the bottom front of the unit, you will see what appears to be a cup. Now since Gerry is from across the pond, its probably not a ruddy cup o' coffee, but a bloody cup o' tea. Most likely Earl Grey! One lump or two Gerry!
Now you know why they boil the water.
Paul
Counting down the days to Orlando 2005
