QOD for 10/28/04 (Foundation)
Originally Posted By: dbush
Sorry for the sporadic QOD lately. It will be fixed.
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Congratulations, the majority rules AGAIN. The correct answer is D.
Dave
Dave Bush
MAB Member
Originally Posted By: mkober
Sorry Dave, but I disagree with your answer (D), calling a crack which increases along its length (I assume you mean the width increases) a V-crack. In the structural inspection industry, the term V-crack typically refers to the cross-section of the crack, meaning the top (at the surface) is widest, tapering down to a small (or zero) opening at the bottom. This profile is typical of all cracks which are only partial-depth, not passing completely through a member The crack whose width appears to widen as it progresses might more appropriately be called “divergent” or “non-uniform.”
Michael J. Kober, P.E.
