Hey Guy’s
be fair and try not to post the correct answer or infer to it until the following day, by all means debate the issues but please repect that some use this as a learning tool.
Originally Posted By: dbush This post was automatically imported from our archived forum.
The correct answer is, as indicated by ALMOST 100% is d. The 2x4 is the industry standard for testing a door, however, be careful, because if they are out of specs, the 2x4 test COULD damage the door. There are several other acceptable tests.
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
I use my shoulder to cause reversal of travel. It’s pretty dramatic, and my customer’s eyes almost pop out of their heads. I usually tell them to have it adjusted to be more sensitice. Even the ones that do not reverse havent been damaged by this test.
– Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Hi to all,
I to use a variation on the "either this door will auto reverse, or dislocate my shoulder" routine.
Most of the standard reference works suggest placing a piece of 4x2 under the door and hitting the close button, but I have heard of may inspectors who have ended up buying new doors because of this.
I think it was Jerry Peck who reported damaging a door or 2 with this method and reporting it as "failed under testing", but I have also read of other isnpectors using a 2 liter soda bottle with a hole drilled in the cap as the test media.
