Hi to all,
Here’s todays question
Regards
Gerry
Hi to all,
Regards
Gerry
Gerry -
Didn’t they teach reduction to lowest common denominator in England when you were in grade school?
Joe
P. S. Stateside, a low pitch is one that is below the knees.
Gerry
Is not this sort of an opinion?? ESP when the right answer is not there
rlb
Joe,
yes they did, unfortunately they did not teach it to framing carpenters over here. When I moved over here a decade ago I had to learn all this weird stuff like pitch, we use degrees or % from vertical ![]()
Regards
Gerry
I’ve always believed Gerry to be a fast learner…when he arrived on our shores, he quickly deduced that driving on the left side of the road would result in his re-orientation to 90 degrees from vertical, and 6’ sub-grade.
Wow, The answers are varied here.
Hi to all,
the correct answer is 4:12 pitch
by way of explaination, it is generaly accepted that
Regards
Gerry
so if 2:12 to 4:12 is low, then B is also correct, because 2:12 is below 3:12… right? …O.K. can i get half credit?
