Originally Posted By: dbush This post was automatically imported from our archived forum.
Well, we have a first. The majority was wrong. The hartford loop is actually used to prevent water from leaking out of the boiler if the wet return leaks.
Here?s how the Hartford Loop works. If a return line breaks, water can only back out of the boiler to the point where the wet return line connects into the equalizer. The Loop works like a siphon that runs out of water. The point where the Loop connects to the equalizer is higher than the boiler?s crown sheet, and that?s what provides the safety. Since the water couldn?t instantly vanish from the boiler, it bought the Dead Men some time to notice the problem and save that wood- or coal-fired boiler. The piping arrangement wasn?t fail-safe, but it was a vast improvement over the old way of returning condensate directly into the bottom of the boiler.
Should you use a Hartford Loop nowadays? I sure think so! Your low-water cutoff should protect the boiler against a sudden loss of water, but if you have a gravity-return system, a Hartford Loop is the cheapest insurance you can buy to back up that low-water cutoff should a return rupture and water suddenly leave the boiler. Low-water cutoffs are great, but believe it or not, there are a few out there that don?t get blown-down once a week. Really!
The above was copied from heatinghelp.com. By the way, I thought it was equalizing pressure also until I started researching the answer (thanks Gerry).
We don't have boilers down here.
Originally Posted By: jmyers This post was automatically imported from our archived forum.
Gerry,
That was a good one. I actually got it wrong and I was with the majority on that one.
After I thought about it, I researched it on the internet and found that very same article that you just posted, although you did not post the entire article. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
I knew that I had seen it in the C & D diagrams but I just could not remember what it was for.
For those of you that are running scared on this one, I just want to add a few words of warning. If you come across a boiler that is low on water, what ever you do, DON'T ADD ANY WATER TO A RUNNING BOILER. At the very least you can crack the sections which are used to heat the water. Worst case, hold onto your hat, you got a one way ticket to space.
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
Quote:
A Hartford Loop is an arrangement of piping between a steam boiler's header and its gravity-return piping. The end of the header drops vertically below the boiler's waterline and connects into the bottom of the boiler. [u]We call this pipe the "equalizer" because it balances the pressure between the boiler's steam outlet and condensate-return inlet. [/u]The "wet" gravity return line, which returns the condensate from the system, rises up from the floor to join with the equalizer at a point about two inches below the boiler's lowest operating water line.
-- Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
