Originally Posted By: dbush
Quick QOD, on my way out.
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Dave Bush
MAB Member
Originally Posted By: jmyers
Originally Posted By: gbeaumont
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Originally Posted By: Kevin McMahon
jmyers wrote: |
What does below the counter mean? Maybe below the counter top? Joe Myers |
ABC Home Inspection, LLC
Quote: |
then receps are not allowed below counter |
Originally Posted By: tallen
I have put the past behind me,
where , however, it now sits, making rude remarks.
Dave Bush
MAB Member
Originally Posted By: jfarsetta
Joe Farsetta
Originally Posted By: rmoore
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Dave Bush
MAB Member
Quote: |
210.52(5) Receptacle Outlet Location. Receptacle outlets shall be located above, but not more than 500 mm (20 in.) above, the countertop. Receptacle outlets rendered not readily accessible by appliances fastened in place, appliance garages, or appliances occupying dedicated space shall not be considered as these required outlets. |
Quote: |
Exception: To comply with the conditions specified in (a) or (b), receptacle outlets shall be permitted to be mounted not more than 300 mm (12 in.) below the countertop. Receptacles mounted below a countertop in accordance with this exception shall not be located where the countertop extends more than 150 mm (6 in.) beyond its support base. |
Quote: |
(a) Construction for the physically impaired.
(b) On island and peninsular countertops where the countertop is flat across its entire surface (no backsplashes, dividers, etc.) and there are no means to mount a receptacle within 500 mm (20 in.) above the countertop, such as an overhead cabinet. |
Quote: |
For kitchen island or peninsula, if the cabinet above is < (less than) 20" to counter, then receps are not allowed below counter |
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
Gerry Beaumont
