QOD (Hopefully back on schedule)
Originally Posted By: dbush
Here is a good one, we all know what to test on a GFCI, but do we know why?
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
I have gotten several PM’s and emails, but the correct answer is D.
Dave
Dave Bush
MAB Member
Originally Posted By: rcooke
dbush wrote:
I have gotten several PM's and emails, but the correct answer is D.
Dave
Sorry I disagree I believe it is E.
If you get between the hot and neutral the GFCI will not trip you make a complete balanced circuit. . The GFCI only gives you protection from the equipment if you get between the hot and ground .
Example a curling iron the shorts to the case and you grab the sink or tap then it will dump.
You can also buy a GFCI that is has a higher trip rate then 5 Milli amps.
Roy Cooke sr Brighton Ont .
d. to protect against shock and will trip at 5 milli amps
92% [ 51 ]
e. none of the above
7% [ 4 ]
Originally Posted By: rwand
I thought a GFCI measured the difference between neutral and hot? A ground is not required for a GFCI to operate. But if you are touching the iron and the sink the difference between the not and nuetral will decrease tripping the GFCI?
Cheers,
Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
http://www.raymondwand.ca
NACHI Member
Registered Home Inspector (R.H.I.)
