When you see an electrical panel seal off with wall paint or any other type of seal on the panel, do you use a razor blade or knife to cut off the paint and seal to open the panel?
Utility knife usually does it…just go slowly so the blade doesn’t get away from you and you end up cutting a line away from the panel.
Jeff
I don’t just because my states SOP is against it.
