Question About Exterior Door Landing Clearance
Hello everyone, I’m glad to be part of the InterNACHI community and wanted to say I hope you’re all doing well and staying safe
I’m a new CPI member and wanted to get some opinions on something I came across during an inspection.
I was checking an exterior door to make sure there was the usual 4–6 inches of clearance from grade to help prevent water or snow from getting into the house. Technically, the clearance was there, but the setup seemed a little odd to me.
Instead of a small step down at the doorway, there was a large landing about 3’x 3’ that sat flush with the door threshold. The landing itself then dropped roughly 4 inches, so technically the required clearance was met.
My concern was that because the landing was so large and flush with the doorway, it looked like snow or water could potentially sit there and work its way toward the door. That said, the landing was sloped away from the house properly, and I didn’t see any signs of water damage around the bottom of the door, so it may be working just fine as is.
Just curious how you guys would handle something like this. Would you call it out as a potential concern, or leave it alone since technically the clearance and drainage were acceptable?
A photo would be very helpful. I do not understand how the landing can be both flush and 4 inches dropped.
You always want the landing to slope away from the home. Landings above the rim band (crawlspace/basement/lower levels) can be a problem.
Here is a case study about high soil levels. Flatwork can result in similar issues.
Pictures are always helpful. :wink:
I’ll be honest, rookie mistake on my part — I got caught up talking with the clients and forgot to take a photo. But this is pretty much what the setup looked like.
What type of foundation?
Let it be. There is no reason to create an issue where none exists.
There will be plenty of legitimate items to report on during your home inspection.
I am very sensitive to the flatwork being above the sill plate or rim band. Good drainage is helpful, but we must also consider wood-destroying insects.
I modified Randy’s graphic to illustrate what is common in my area. Blue is water, brown is termites :slight_smile:
Thanks Randy :wink:
Here is an example from the field.
I agree on considering WDI.
Pouring a concrete sidewalk against the siding like you posted here is quite problematic:
If the issue was like @jdreer posted and reported to us with sloping away landing and no visual signs, I don’t see your issue in his situation. However, expert inspectors in the south like yourself that deal with the WDI regularly have different views and concerns than we northern inspectors. So, by all means report your observations and concerns to best serve your client.
I appreciate your view on it.
I wonder where @jdreer inspects.
Plus pictures would help.
It sounds like a poor design with the flatwork at the same level of the interior floor of the home, and that is something we note in my company. If it is a pre-existing home that has stood the test of time and shows no issues, it would be a note to the client to watch the area for any signs of water seepage. If it were new construction, it would be a Red Flag issue with a recommendation to correct it.
I appreciate the support as a new inspector. It is greatly appreciated. Thanks again for your insight.
Hey Brian, thanks for your help. Got figured out. It is a poured concrete foundation to answer your question. Thanks again.
Ty I agree
IMO, it doesn’t.
The term “Poured Concrete Foundation” applies to multiple foundation types.
I hope you’re more specific in your Reports.
Here is one from today. EIFS stucco clearance issues, downspout discharge, negative slope, and evidence of ponding on the landing; all add up.
An inspector has to decide what to report on. I think it is pretty clear-cut.
Siding clearance issues have been very common finds for us this spring. I’ve always had a hard time trusting the concrete porch to rim joist transitions in new construction. It always seems to be either totally closed up and not visible at final inspections, or the flashings aren’t installed yet when we see it at predrywall. Do any of you guys ever see floor joists hung from the foundation wall so that the concrete deck meets the concrete foundation wall instead of framing?
I’m thinking he meant 4-6 inch from edge of 3x3 landing making it step down aren’t of landing
