Looking for some input from other inspectors regarding roof ventilation.
The home has a gable roof with cathedral ceilings (no attic space). The roof assembly currently has a ridge vent installed, but there are no obvious continuous soffit vents. The soffits have a few older round metal vents, but it is unclear whether those actually open into the rafter bays or if they are blocked by insulation.
The ceiling insulation appears to be faced fiberglass installed in the rafter cavities. I have not yet confirmed whether vent baffles/chutes are present in each bay to maintain an air channel from the eave to the ridge.
My understanding is that with cathedral ceilings, each rafter bay should have a continuous ventilation channel from soffit intake to ridge exhaust, and that ridge vents generally require balanced low intake to function properly.
Questions for those with more experience with this configuration:
• Can a ridge vent function effectively if soffit intake is minimal or unclear?
• Would small round soffit vents typically provide enough intake for ridge ventilation in a cathedral assembly?
• If the soffit vents do not connect directly to the rafter bays (blocked by insulation, no baffles), would the ridge vent provide any meaningful ventilation?
Just looking for some professional opinions and best practices for this type of roof assembly.
Thanks.
