I haven’t seen many new builds with the following construction method. The treads fit into routed grooves and each tread is then shimmed and then a strip is stapled and glued where the riser and tread meet underneath. Is this a common method? This is for a young couple who are buying a house yet to be built and they wanted me to check out others in the neighborhood that are in the process.
Last time I saw something similar to that the plans included an option for factory fabricated stairs vs site built.
Seems that fastening in place method(s) would be the critical detail.
It is a cheap way to build stairs offsite and slap them in place.
Did you get a picture of this to follow up on?
i cant imagine osb holding up very well at the overhang if they are going this cheap on the stairs what else are they cutting corners on ???
What?
You want the gun safe in the downstairs? Haha
Any and every single little thing they can find a way to cut a corner. ![]()
Okay…so what about LVLs, Glulams, PSLs, LSLs, OSLs, I-joists, and so on? You do realize a lot of things have to be built with engineered wood now a days because you old timers used up all the good wood? With labor being so expensive nowadays, hand cut stringers, rafters, and so on doesn’t make any sense for your average person buying a new construction as the additional costs will just be piled onto them. Personally, I would rather more engineered stuff be used than hand cut because you are much more likely to find a low wage laborer on site than a skilled carpenter. There is no “finesse” on any framing or anything for that matter, just slap shit together.
Thanks, Larry. I actually didn’t notice the label since I was looking mostly from the bottom and just took some general pictures otherwise. Thanks for pointing that out! This wasn’t a real inspection, just a walkthrough with the kid’s father. I did notice some other things that were no-no’s that will be things to look out for on their home when it’s built.
It looks like it may have some installations details on the label that you would be able to verify on site, David. ![]()
I can’t imagine that building this contraption was quicker, cheaper, or easier than cutting or buying actual stair stringers. On the plus side, it did use up some scrap material.
Basically almost every single new construction around here has similar prefabricated stairs. The stringers have to be nailed into the studs nearby for support. You can’t clear span them from the header to the bottom support like the 3 hand cut stringers of old. When the central stringer was lost, the 2 side stringers now take on more load. Not to mention the new stringers are thinner in overall thickness AND they are notched even thinner for the treads/risers.
I’ve seen one 10 - 15 year old house framed with this type of prefabricated stair stringer. It was a set of basement stairs that had a central landing too so the stair span would be even shorter than your typical 1st floor to 2nd floor stairs. When walking on the stairs by myself, the stairs flexed noticeably at the middle and if you pressed your weight down a bit, you can actually see the stringer separating vertically from the drywall. Luckily, this was on a basement so the underside was open to see from the utility closet below. As suspected, the stringers were not nailed to the studs and there were some small cracks on one of the stringers already.
Manufacturing issues such as the little wedges falling out, or missing, not tight, gaps, and so on are occasionally seen.
Installation is even more important, especially the stairway opening rough framing width compared to the stairs. If there is a decent gap between the stringers and the studs, it must be shimmed. Or, you run into the problem of nailing the stringers to the studs and prying them away from the treads/risers. They will separate whether now or down the road and that’s a big problem. I was lucky to see this happen on a short set of stairs once at another house. The underside was not visible though.
Here is an installation video from a different manufacturer.
I am sorry but OUCH” I am an old school man I just dont know about bringing that old piano up those stairs, I have never seen them in my area but looking at videos, they should have a video showing heavy weight items being brought up stair case, with camera from below then I can be convineced.
You are too old to be carrying the piano!
Factory-made… They are fine.
Those are not solid one piece strigers.
IRC: Stringer Structure and Spacing.
Stringer Spacing: Cut stringers should be spaced no more than 16 to 18 inches apart (center-to-center).
Stringer Size: Typically 2x12 lumber is required.
Those are site manufactured.
Look at the fasteners.
Over driven.
Not perpendicular.
I would certainly mention my observations and refer for further evaluation.
Thus Subject to Recall… keep your eyes and ears open!!
You may be right there Bob. ![]()
