Originally Posted By: tallen This post was automatically imported from our archived forum.
Greg Fretwell wrote:
I will give you a hint, the author was a PE and much of the original material in "The" grounding book that bears his name was in his book called "Designing Electrical Distribution Systems for Safety", published in 1966.
I have that book and many others that have Joe tedescoes name as a contributer.
-- I have put the past behind me,
where , however, it now sits, making rude remarks.
Originally Posted By: bmarrone This post was automatically imported from our archived forum.
Hi Joe
I lost electric to my garage I have a separated garage the wire goes from my house under ground to the garage. when I touch my water hose I feel a tremmer  and if I stand on a wet place in my garage I feel the same tremmer  not a shock. Can that be from a broken wire that go to my garage and giving us these tremmers
Originally Posted By: jtedesco This post was automatically imported from our archived forum.
bmarrone wrote:
Hi Joe
Thanks
Barney Marrone
Hi Barney:
If the supply is run underground there may be some damage and a break in the neutral, if overhead look at the run from the beginning to end.
Best approach would be to run a new circuit if possible. See the new NEC Forum under education. If you want me to post this question there please let me know so we can pinpoint the possible corrections to the problem.
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
First turn off the power.
If I was looking I would start with finding out if there was any digging, stake driving or other disturbing of the ground. If nothing comes up, Then I would start with the boxes. Make sure nothing looks bad. At a certain point Joe may be right. If everything above ground is OK you probably have a damaged cable underground and fixing it is not likely.
The more testing you can do along the way the easier this will go.
Originally Posted By: wdecker This post was automatically imported from our archived forum.
But, I agree with Greg. Get a qualified electrician.
It is all well and good to discuss these things her, in an academic type forum and such, but with the type of symptoms you stated, GET AND ELECTRICIAN!
Thanks a lot guys
I was looking but I have no Idea what I’m looking for other then a broken wire, And yes the wire runs under ground, But when a electrician comes and runs a new line to the garage and make the lights go back on what happens to the tremmers I been feeling with the broken line? I just hope he can find that problem I can live without the electric in my garage.
