Arc-fault circuit-interrupter (AFCI) protection is required for most 120-volt, single-phase, 15- and 20-amp branch circuits supplying outlets or devices in habitable areas of a dwelling.
These locations include bedrooms, living rooms, family rooms, dining rooms, hallways, closets, kitchens, laundry areas, and similar rooms.
AFCI protection helps reduce the risk of electrical fires caused by dangerous arcing faults in wiring or connected equipment.
Welcome Osama. The latest version of the National Electric Code (NEC) mandates AFCI protection in all those areas. However, those requirements were developed over time. In addition, states and local jurisdictions can adopt and modify the NEC on their own timetables. Therefore, what was mandated at the time a home was constructed requires some investigation that is beyond the scope of a home inspection. It is good practice then for the home inspector to simply recommend AFCI in all of those areas for the safety of occupants.
It actually depends on your local code adoption. Localities regularly amend exactly what portions of code they adopt. Some areas have rescinded or deleted the AFCI requirements. You need to check your local municipality or call their code compliance office.
And some may ask… “Who in their right minds would do this”?
Honestly, it all begins with the two largest RE Lobbyist Groups in the U.S… the (often combined) team of the NAR and the NAHB!!
