Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@internachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) A floor joist in a crawl space has been cut where the toilet drain passes through the floor. The joists are 2X6 spaced 16” on center. The inspector should recommend that
a) The buyer monitor the floor. Floor systems such as this have redundant framing and removal of one is insignificant.
b) A contractor should support the cut joist with new piers and posts from below.
c) The cut joist should be headed off to adjacent framing members to distribute the load.
d) A contractor be contacted to determine what is needed and make repairs.
2) Which set of building terms do NOT belong together?
a) Cripple, trimmer, purlin
b) Arch, header, lintel
c) Rafters, ceiling joists, trusses
d) Sheathing, flooring, decking
3) Inspecting a very old country house, a gurgling sound is heard from the tub drain when the toilet is flushed. Which of the following is the MOST likely explanation for the sound?
a) Water discharging from the toilet is pulling water from the tub trap.
b) The tub drain is partially blocked.
c) Water discharging from the toilet is pushing air through the tub trap.
d) The branch drain is partially blocked downstream from the tub.
4) Where might you expect to find a window with safety glass?
a) Less than 18” above the floor
b) Less than 24” above the floor
c) Above a kitchen sink
d) On the second story
5) The final decision to enter a crawl space is made
a) When the home inspection is booked.
b) By the homeowner.
c) By the home inspector.
d) By the client and agent.
