Questions of the Week 8/10/25
Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) Fused neutrals -
a)    Provide enhanced protection for the neutral wire
b)    Will never trip because the voltage drop across a neutral wire is negligible
c)    Are required on multi-wire circuits
d)    Are dangerous
e)    Provide double protection for the circuit
2) Knob-and-tube wiring issues include all of the following except -
a)    Connections to modern wire not in boxes
b)    Wires buried in insulation
c)    Fused neutrals
d)    Brittle wire, insulation or sheathing
e)    Over-heated neutrals on multi-wire branch circuits
3) Twist-on connectors (wire nuts) -
a)    Replace junction boxes
b)    Are not permitted on knob-and-tube wiring
c)    Are not permitted on aluminum wiring
d)    Are also called solder less connectors
e)    Should be used only on soldered connections
4) Of the GFI’s that you find in a house, which ones must be tested?
a)    All of them
b)    Those at receptacles
c)    Those at the panel
d)    Exterior GFI’s
e)    Kitchen GFI’s and exterior GFI’s
5) What happens if the neutral wire bypasses the service box?
a)    The house electrical system won’t work properly.
b)    The neutral wire may overheat.
c)    The grounding electrode conductor can’t get to the water piping and/or ground rod.
d)    The neutral and grounding system will not be properly connected.
e)    The ground wire will carry electricity under normal conditions
Great QOTW Peter! :+1:
d e c e d
____________
Great QOTW, Peter. :+1:
  1. D
  2. E
  3. D
  4. A
  5. D
Thanks Peter!
Great questions, Peter, :thinking:
good job sir ! and I win again !
where are the spicy tacos ???
Thank you for the quiz questions
1-D
2- E
3- C
4- A
5- D
Bump.. :eyes:. What’s up?
A few more days !!
Good questions Peter! Thanks for giving your time for QOTW. :cowboy_hat_face: :united_states:
David Freund is this weeks winner !!
WTG David !!
Congratulations, David,
Great job David!
Congrats David!:+1:
Way To Go David @dfreund !!! :collision: :heavy_dollar_sign: :collision: :money_bag: :collision:
You know how to claim your prize.
And, you are listed here:
https://www.nachi.org/chapters/inachiawards/pages/InterNACHI-award-winner-recipients-to-date
WTG, David. :+1:
nice work !!!
Congrats on the win David! :+1:
