Welcome To Questions of The Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
The function of a footing is to
a) Provide lateral support for foundation walls
b) Transmit the weight of the house to the soil
c) Provide support for the basement floor slab
d) Prevent leakage into the basement
e) Resist hydrostatic pressure -
Footing failures can be most positively diagnosed by
a) Sagging floors
b) Basement leakage
c) Vertical cracking in foundation walls
d) Horizontal cracking above windows
e) Bowing foundation walls -
Where you have found evidence of footing settlement, how can you predict whether there will be further settlement?
a) Count the number of planes of movement
b) Determine the type of foundation material
c) Determine when cracks were repaired last
d) You cannot predict settlement from a single inspection
e) Determine the depth of the footing -
When installing a basement walkout an important consideration often overlooked is
a) Undermining footings
b) Potential for termite infestation
c) Frost penetration below the footings
d) Handrail for stairs
e) Damage to foundation walls on the original building -
Differential settlement is
a) Settlement that occurs at a control joint
b) When one part of the house settles and the rest does not
c) The cause of all horizontal foundation cracks
d) Associated with shrinkage cracks
e) Never a problem in organic soils
