**** Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file.
Winners of the Questions of The Week shall request their prize by emailing [email protected] and submitting their Mailing address for shipping.
GOOD LUCK! ~ GO!
What determines where a lightning strike will hit the ground?
2) When fire depletes oxygen levels to _______% a person experiences Headache, dizziness, nausea, fatigue
3) Flexible water connections are required to be _______
a) Accessible
b) Readily Accessible
c) Limited to first-floor installations
d) Properly supported
e) Easily dismantled
4) Federal and state regulations both require certain warnings to be conspicuous. As a home inspector, you will often have to determine whether or not hazardous components are adequately labeled.
Which of the following would a reasonable person consider to be conspicuous
a) UNPLUG POWER BEFORE TOUCHING CIRCUIT (with graphic warning symbols)
b) UNPLUG POWER BEFORE TOUCHING CIRCUIT (without graphic warning symbols)
c) DANGER ENERGIZED EQUIPTMENT (with graphic warning symbols)
d) DANGER SHOCK HAZARD UNPLUG POWER BEFORE TOUCHING CIRCUIT
e) A B
f) A B D
5) What is Electromotive force?
a) Current
b) Power
c) Force
d) Voltage
e) Don’t tase me bro!
EXTRA CREDIT!
WHO sang this on WHAT song?? she said life is one big scam always in a jam
When the difference between the negatively charged middle portion of the cloud and the ground become large enough to overcome the insulating effects of the air.
1- Difference between the electrical potentials. ( When the lower part of the cloud becomes negatively charged, objects in the air and on the ground below become positively charged.)
2- 10-15%
3- A
4- F
5- D
The location of the thunderstorm overhead alone determines where lightning will hit the ground. A lightning bolt that is several miles long, generated by a cloud that is more than 6 to 10 miles high, is not going to be influenced by your jewelry, or even your house https://stormhighway.com/small_metal_objects_attract_lightning_myth.php
a) Accessible
a accessible
All flexible water connections are required to be accessible. This means that they can be concealed in a cabinet or behind an access panel, but they must be accessible https://www.tests.com/practice/plumbing-practice-test
4) Federal and state regulations both require certain warnings to be conspicuous . As a home inspector, you will often have to determine whether or not hazardous components are adequately labeled.
e) A B
f) A B D
A B https://www.tests.com/practice/Home-Inspector-Practice-Test
a) Current
b) Power
c) Force
d) Voltage
d Voltage
Explanation: Electromotive force is not actually a force. It is basically a voltage. It is the voltage developed by any source of electrical energy
EXTRA CREDIT!
always in a jam
Sir Douglas Quintet - Romance Is All Screwed Up 1994
Well I’m going to go ahead and start a discussion on that first question. That answer is false. The location of a thunderstorm overhead is definitely not the only determining factor of where it will strike the ground. “Thunderstorm” clouds don’t necessarily hit the ground all the time. The answer I gave and the answer @sfloyd2 are the accurate determining factors. Mine came from a NOAA website.
