A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified .
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
ID POLICE STAMP ROLLER
Good luck!
What is under roof called
What is top of roof called
2) What is the appropriate height for a gas water heater?
3) What is before you that cannot be seen?
4) Is it OK to pour bleach, vinegar, Pine Sol down your drain?
5) How can you keep a room warm in the winter?
WHO sang this on WHAT song?? So long darlin’
No worries Martin! I’m in trouble anyways with #1 'cause I made it a crazy question.
You & Ryan are the only two responses so far -
might have to split the prize… … …
Congrats to David Mattoon & Ryan Uecker.
By my crazy answers, they got 3 of 5. #1 was a matter of prospective, I guess… … …
I was looking for something else for #4. Martin will straighten my mess out.
Welcome Lisa ~ hope to see you next time!
Soffit—The area that encloses the underside of that portion of the roof that extends out beyond the sidewalls of the house
The roof ridge, or ridge of a roof is the horizontal line running the length of the roof where the two roof planes meet. This intersection creates the highest point on a roof, sometimes referred to as the peak
Gas hot water heaters have to be at least 18" off the floor because combustible fumes sink, and to provide adequate air intake
your future
4) Is it OK to pour bleach, vinegar, Pine Sol down your drain? Not bleach
Bleach is a powerful, toxic substance that should be used carefully and properly, and pouring it down a drain is not a proper use. Bleach can react with other substances in your pipes, potentially release fumes, and further plug up the system
Ceiling fans can keep a room warm in the winter due to the fact that the hot air rises. When its turned on, it circulates it throughout the room
So long darlin’ Scandal ~ Goodbye To You
