A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
** Free pass to say whatever you want without being flagged for three days
GOOD LUCK!
Stucco cracks occur due to __________.
a) the natural shrinkage of stucco
b) the natural shrinkage of wood
c) the uncontrolled movement of the structure
d) OJ Simpson
2) What trips a main disconnect breaker?
3) What are the two units used to measure objects?
4) Marcel Cyr wants to know:
This is a secondary effect in shears and especially movements of frame members induced by vertical loads acting on laterally displaced building frame
a) P-delta effect
b) Orthogonal Effect
c) Vertical Effect
d) Irregularity Effect
e) truss uplift
5) What is the most grown crop in the US?
Here we go ~ good luck with this one!
WHO sang this on WHAT song? Pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa
overcurrent – that or service personnel or EMS crews depending.
what object? mass, volume perhaps the SI units of kg or cubic meters. The Imperial system is a bit different measuring weight not mass in pounds. There are plenty of ways to measure objects, and a variety of units used.
a
Corn (by dollars and weight and area of planted crop)
Champagne – Pa Pa Pa Pa Pa
Pa Pa Pa – Los Prisioneros
2 direct short within the home electrical system, or an over loaded condition of the electrical system.
3. Mass and volume
4. A
5. corn
6. Mamas and Papas
1 - a, b, c
2. when overload by trying to draw more power than the wires can safely handle
3 IMperila standard and non standard
4 C
5 Corn
6 the Mamas and Papas
Well… … …No big winner, so you are all big big winners!
Merry Christmas from InterNACHI & your Awards Committee.
d) OJ Simpson a b c 5 Common Causes of Stucco Cracks (When to Worry)
Lightning strikes, power surges from the utility company, or an overload to the electrical panel can all cause the main breaker to trip. If an individual circuit breaker fails and loses its ability to trip as designed, it may actually be the main breaker that trips to provide the secondary safety shutoff.
3) What are the two units used to measure objects? mass and volume
Mass and volume are two units used to measure objects. Mass is the amount of matter an object contains, while volume is how much space it takes up.
Example: A bowling ball and a basketball are about the same volume as each other, but the bowling ball has much more mass.
a) P-delta effect
c) Vertical Effect
e) truss uplift b Orthogonal Effect
5) What is the most grown crop in the US? Turfgrass is actually the biggest irrigated crop in the United States.
It’s everywhere — on our lawns, peaking out of sidewalk cracks, blanketing golf courses.
A study, published in the journal Environmental Management, found that over 40 million acres of land in the continental US has some form of lawn on it. We spend 36 billion annually on lawn care.
WHO sang this on WHAT song? Pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa pa Surfin’ Bird The Trashmen
