HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time. Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing [email protected] and submit your Mailing address for shipping
GOOD LUCK!
**Choose your prize from the following list:
(more than one winner)
>$50.00 gift certificate from Inspector Outlet
Case of books “Now That You’ve had A Home Inspection”
3 cases of “Milk Bones” liberated from Kevin Leonard’s kitchen cabinet… someone’s NOT happy!
Which insects are considered Scavengers?
a) Houseflies
b) Ants
c) Cockroaches
d) A & C
e) All of the above
2) Gravity Load
a) An assemblage of building elements that transmit loads from the structural system into the earth
b) A load caused by weight (e.g., of snow, occupants, furnishings, or the structure itself)
c) The weight of people, furniture, and other movable objects contained within a building
d) All liquid and solid material that drains from plumbing fixtures in a building or other facility
3) _____may substitute for an air conditioner most of the year in most climates
4) The misuse of ___ cause more than three thousand house fires every year
The window guard was missing a latch for ease of egress. This is a safety concern. Correction is recommended by a qualified window contractor.
The gutters appear to be installed below the roof edge. This may reduce proper drainage. The gutter and downspout was damaged. The downspout extension and splash block was missing. This may allow unwanted moisture along the foundation. Further review and adjustment/repairs as needed is recommended by a qualified contractor.
Negative grading was observed along the wall below the window. This may allow unwanted moisture along the foundation. Correction is recommended by a qualified contractor.
The trim near the down spout had peeling paint. Scrape, caulk, prime, and paint is recommend for all exposed wood surfaces. A fence immediately adjacent to the building was observed. Maintaining clearance and airflow to reduce potential moisture accumulation at the building is recommended.
The stucco exterior wall covering was in contact with the brick walkway. Industry standards recommend approximately 2 inches of clearance between stucco and hard surfaces to reduce moisture intrusion. Further evaluation and correction as needed by a qualified contractor is recommended.
I believe the song is sung by Marty Stuart and His Fabulous Superlatives and is called “ Don’t Leave Home Without Jesus”
a) Houseflies
b) Ants
c) Cockroaches
d) A & C
e) All of the above e) All of the above
2) Gravity Load
d) All liquid and solid material that drains from plumbing fixtures in a building or other facility b) A load caused by weight
Gravitational loads refer to the forces exerted by gravity on a structure, which result in varying shear forces and bending moments, significantly impacting the design and fatigue life of components
3) _____may substitute for an air conditioner most of the year in most climates Whole house fan
Every year electric extension cords cause about 4,000 trips to hospital emergency rooms. The misuse of electric extension cords and power strips also cause more than three thousand house fires every year, killing about 50 people and injuring over 250
No emergency egress from window
Gutter poorly configured
WHO sang this on WHAT song… you may forget your keys you may forget your phone
Marty Stuart And His Fabulous Superlatives
Sang by “Cousin” Kenny Vaughn
so, when did they stop calling live load and dead load? i really need to catch up on terminology i suppose. i mean i get the primary instead of master because of it work and it started there decades ago, but did they stop using live and dead load? i thought i had a question about that on my nhie test.
