Questions of the Week for Sept. 25th
Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
**MOST members are eligible… … …
Easy week for you guys to give Marc a rest. LOL
Good luck!
To help everyone, I decided to add the answers at the bottom, just pick the right one as would be shown in Inachi https://education.nachi.org/coursemedia/course-57/documents/StudyGuide_How%20to%20Inspect%20for%20Moisture%20Intrusion.pdf
1). Most homes are designed for no more than ____________p.s.f. of roof covering.
2). Roof sheathings in high wind areas should be attached with ________ or _______ at _____ on center on all framing members.
3). Moisture and water vapor moves in and out of a house in 3 ways; with air currents; by diffusion through materials and by ____ ____.
4). If significant interior air leaks into an attic, ________may not be sufficient to prevent moisture and condensation problems.
5). One of the oldest and most trustworthy practices used to prevent wood and other moisture-sensitive materials from decaying is _____ _____a constant uptake of moisture from the ground.
Answers;
Pick the right one
Heat transfer heat transfer
8d ring shank
5
8d common
4
6d ring shank
1-1/2" staples
12’
separation from
Ventilation
air transportation
circulation
6"
3
8d galvanize
air movement
pressure treatment
thermal diffusion
Great questions to ponder, Good Luck.
200w (1)
Very good questions, Marcel!
Great questions, Marcel. :slightly_smiling_face:
Nice work Marc !!!
I deny everything
all of the above !!!
1=5
2=8D,6
3=Heat transfer
4=Attic ventilation
5=Separation from
Close but no cigar. So keep playing everyone.
The first Member to fill in the blanks properly wins.
All the blanks are filled. :grin:
I got all my answers from the study guide you posted.
  1. 5
  2. 8d, ring shank, 6"
  3. heat transfer
  4. attic ventilation
  5. separation from
Not quite,
1=5
2= 8d ring shank, 8d common, 6”
3=Heat transfer
4=Attic ventilation
5=Separation from
This is where I got the answer. all the nail are 8d.
It doesn’t matter I was going to give my prize to someone anyway.
Roof sheathing in high–‐wind areas should be attached with minimum 8d (0.113–‐inch diameter) deformed shank nails, or 8d common nails(0.131–‐inch diameter)spaced 6 inches on center at all framing members.
Congratulations Tony Frydenlund for getting the right answers to fill in the blanks.
Follow the directions to claim your prize.
Thanks for participating.
Thank Marcel for doing this. We all appreciate you.
Congratulations Tony!
Yea Tony!
Congrats! :cowboy_hat_face:
Congratulations, Tony, Awesome!!
