A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified .
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
What do plumbers call a lubricating sealant which they use very regularly?
a) PVC cement
b) Gorilla Glue
c) Dope
d) Silicone
e) Coke
2) Which of the following is the proper term for piping that delivers potable water from a water source to a water-distribution system?
a) Water main
b) Water supply
c) Either a or b
d) None of the above
3) Which one of these is the roof’s eave?
1 - c)
2 - a)
3 - c)
4 - None of the above
5 - Qualified contractor recommended for repairs above patio door cantilevered area as per good building practices.
1.C
2.A
3.none of the above.
4.none of the above
5. Moisture intrusion, rot, structure failure, Evaluations, and repairs to be made by a licensed building contractor.
EC. Hole in a bottle by Kelsea Ballerini
Substandard design and workmanship observed at the cantilevered balcony. Further analysis, redesign, and repair by a qualified contractor is recommended.
See my proposed Nachi course module on EEE structures, in PDF format at https://www.dropbox.com/t/4yfeTr9FYt1dke4X
My first look, carefully, will be for level of rust on the remainder of the light fixture.
The cantilevered balcony structure has been deemed unsafe, in need of repair and further evaluation by a licensed building contractor. Noticeable wood rot and moisture intrusion observed with the structure.
