Questions Of The Week October 2
Welcome To Questions of The Week!
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and ineligible members will be disqualified.
The correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
GOOD LUCK!
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
Be honored to host Mr. Kevin Leonard at your home on Halloween night to assist giving out the free supplied candy & caramel apples.
  1. Please inspect this
2) The potential difference in an open circuit is
a) Zero
b) Unity
c) Infinity
d) Circuit does not exist open
e) don’t tase me bro!
3) 25% to 40% of a typical building’s energy use can often be attributed to ___
4) Please inspect this
5) One of two points, such as the ends of a magnet, that have opposing magnetic qualities
a) magnetic pole
b) magnetic force
c) magnetic field
d) electromagnet
e) b & c
WHO sang this on WHAT song?
she don’t mean nothing
Great QOTW, Marc. :+1: :slight_smile:
Great questions, Marc, :thinking:
Great questions Marc!!
Thanks for posting. :+1:
Darn! I wish I could win! I’d be honored to show Kevin a good time around here. :grin:
Great questions Marc! Thanks for taking the time and putting in the effort do the Questions of the Week, my friend. :+1:
As long as Marc is buying, I’m game. :sunglasses:
Nice questions Marc !!
Hi Marc. A long time ago I replied to one of these, and promptly got chewed out and my post removed because I replied to the post to answer the questions. Now, I see the instructions say to do just that.
OK, I’m game. I’ll try once more.
  1. There were multiple electrical issues such as double-tapped circuit breakers, under sized breakers, mismatched breaker and wire combos. An electrician must evaluate and make needed corrections.
  2. a) Zero
  3. HVAC
  4. The T&P release valve drain line had negative slope, which is considered to be “trapped”. The condition is unsafe, and must be corrected.
Details: A trapped T&P drain line can be blocked by minerals left behind by evaporating water when the valve has a small leak, by too many right angle bends, by the weight of water in a vertical pipe, and any combination of those conditions. A trapped T&P drain line can cause the water heater to explode should the T&P valve have to release. The drain line needs to have proper gravity flow to its end (at exterior of building, a proper distance from the ground, or above a drain line, depending on the location of the water heater). Repairs needed by a licensed plumber.
  1. a) magnetic pole
  2. Tequila makes her clothes fall off by Joe Nichols
Hi Daniel!
Not sure what, if anything, could have happened in the past.
But you’re good & THANKS for being here!
ps… If something did occur, it was Larry’s fault. … …
And, I take full responsibility.
Who are you again?
bump
After a considerable Committee meeting, we figured out the winner is
Dan Evans - CONGRATS Dan!
Hope to see you again.
FPE Stab-Lok main disconnect panel/double tapped
a) Zero
b) Unity
c) Infinity
c) Infinity
Explanation: In an open circuit no current exists due to non-existence of loops. Also voltage/potential will be infinity in an open circuit
air infiltration
water heater TPRV drain line reduced in size,
improperly routed upwards
a) magnetic pole
b) magnetic force
c) magnetic field
d) electromagnet
e) b & c
a) Magnetic pole
Joe Nichols ~ Tequila Makes Her Clothes Fall Off
Congratulations Daniel Evans! :heavy_dollar_sign: :firecracker: :boom:
You are listed here with many other winners:
WTG, @devans5. :+1: :slight_smile:
WTG Daniel !!
Congratulations on the win Daniel. :+1:
Ha! Thank you all. But… it appears that I was the only submitter? If so, I can understand the “considerable” discussion needed since I got some of them wrong.
I always enjoy the questions, because al least one will stump me and I will have to do some research and self-education.
Thank you for the opportunity.
Nice job Dan!
Yes, well, many answer in spirit. So, there’s that we must deal with. And, that can be grueling. Hence, the considerable discussion needed.
Thanks for participating Daniel!..really. :grin:
