Welcome to another round of Questions of The Week!
Please read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions, and the eligible member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice! https://certifiedmasterinspector.org/video-contest
Good luck!
A waste pipe from the disposal should have a trap installed …if…
a) also connected to a dishwasher drain line
b) not connected to an air admittance valve (AAV)
c) does not matter if higher than bottom of disposal
d) there is is double sink
2) Direct current (DC) voltage is always positive (or always negative), but it may increase and decrease
True or False
3) Name a power supply containing
~~Negative outputs
~~ Zero volts (0V)
~~Positive outputs
4) Why is High voltage is not inherently dangerous?
5) Don’t worry how old this is, because it will never rot away!
~~ ~~ ~~ ~~ ~~ ~~ ~~ MUSIC EXTRA
WHO sang this on WHAT song? Is it ever gonna end?
CONGRATS to our most recent Member Of The Year, Joseph DePiero!
You got 4.
I’m not sure about #3 where you said clamper.
I thought it doesn’t function as a dual but I think you will know better than I.
Not much action here so it’s lonely at the top!
d Garbage Disposals for Inspectors - InterNACHI®
True or False
True
~~Negative outlets
~~ Zero volts (0V)
~~Positive outlets
Dual Supply
High voltage is not inherently dangerous. Track your feet across carpet on a dry winter day and you will charge your body to several thousand volts. If you then touch metal, the resulting static discharge will have a voltage many times greater than a typical home’s electrical system, yet you will be perfectly safe because the current is not sustained.
Bees pollinate 80% of the world’s plants including 90 different food crops.
1 out of every 3 or 4 bites of food you eat is thanks to bees.
The honey bee is responsible for $15 billion in U.S. agricultural crops each year.
Honey is the only food that does not spoil (bacteria can’t grow in it, and because of it’s low moisture content and low pH – honey can last indefinitely).
MUSIC EXTRA
Donnie Iris (aka Dominic Ierace) - Ah Leah
