A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice! https://certifiedmasterinspector.org/video-contest
2) Existing knob-and-tube wiring should be replaced
a) because its design is known to be defective
b) because it is prone to be a hazard
c) if a grounded circuit is desired
d) because it is no longer allowed by any electrical codes
3) Which of the following requires aesthetically pleasant water?
a) Domestic use
b) Industrial use
c) Irrigation
d) Aquaculture
e) none
4) How can I tell if my floor drains are trapped?
5) Interior basement stairways should have
a) graspable handrail on at least one side
b) adequate headroom
c) adequate lighting
d) risers of equal height
e) a & d
f) all of the above
Extra Credit Get this & win the famous INachi Inspectorsaurus T-Shirt
WHO sang this on WHAT song? Neighbors knocking on my wall
1- Turkeys can be kept frozen in the freezer indefinitely but cook within 1 year for best quality.
2- b
3- b
4- If there is standing water in them
5- f
I came up with the same answers as Marcel so I will not post, But I will change the answer to question 4, It is when you hear help let me out. Good luck Marcel G.
c
a) Domestic use
b) Industrial use
c) Irrigation
d) Aquaculture
e) none
b
Industries need aesthetically pleasant water with low turbidity, colour, taste and odour, absence of macro-organisms. The water should be free from organisms harmful to health
Pour water into the opening (at least 2 gallons) and visually inspect by looking down the opening. If there is considerable water standing (so that it fills the pipe), then the drain is trapped. Check it again a couple of hours later to be sure the water hasn’t drained out. https://www.marionohio.us/wpc/sewer_gas
e) a & d f) all of the above
Extra Credit
The Apartment Song ~ Tom Petty
Congrats Sir Roy Lewis ( rlewis5 ). Thank you for allowing me to ride with you again today and for giving me tips on the inspection software as well! Words can’t express the amount of help you have given. Thank you sir!
